Quiet Ring & Pinon set for my GM, 8.2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2009, 06:59 AM
In my earlier post I asked about reducing the whine from the rear end of my 58 Impala and the consensus was learn to live with it or replace it. I'm considering replacing it and I would appreciate some advice on which brand of gear set to go with. This is not a performance vehicle so I dont need or want a performance gear set, especially from Richmond. My main concern is QUIET. I would like it to be as quiet as my Wife's Lexus..........don't even know it's there. Ratio is 3.55 (non posi) and I would use existing axles, spiders, housing and yoke unless there is a reason not to. I have heard Motive is a quiet gear but have never used one. Anyone have any suggestions?
Jim
Old 12-31-2009, 07:20 AM
302 Z28's Avatar
Not Richmond Gear. I replaced the R&P in my car last year with a Yukon R&P and I am completely satisfied. Read the warnings on the Richmond gear set, they specifically state that it may make a little noise. Richmond Gear is usually recommended for drag or race cars where a quite gear set is not that important. Whatever gear set you buy the most important aspect is setup as far as how quite it's going to be. And don't let price be the deciding factor in your decision.
Vince
Old 12-31-2009, 07:52 AM
Crosley's Avatar
Wiki Edits: 1659
I have Richmond 4.11 gear set in my drag car.... it is noisy.
i've changed the settings in the 8 inch Ford diff and it still is noisy
Old 12-31-2009, 09:29 AM
big gear head's Avatar
High Performance Rear Ends
I've installed gears from all of the manufacturers and most of them are quiet. Sometimes you get a noisy gear from a company that usually has quiet gears. I've had GM, US Gear, Richmond, Motive and Yukon gears that had a slight noise in them even though the pattern was very good. Most of the gears from these manufacturers are very good, but sometimes a bad one gets through. I've been dealing in Yukon gears for the last few years and I've only had a problem with the 9 iinch Ford 3.70 gear. I haven't used any of their '55-'64 8.2 gears.
Old 12-31-2009, 10:03 AM
Ya they make a wee noise but nuttin a good cam,open exhaust and 100 watt stereo cant cure
Old 12-31-2009, 10:11 AM
prostreet6t9's Avatar
Differential/Driveline
I've installed many Yukon and Motive set's in the 8.2 and have had good luck with both.
Old 01-03-2010, 07:14 PM
1930u's Avatar
Last journal entry: 1930u more fuel line plumbing
My Richmond 4:11 makes a lot of noise.
Old 01-03-2010, 09:00 PM
68NovaSS's Avatar
Wiki Edits: 9
Strange 4:11's in a 9", pretty quiet.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Ring & Pinion Tooth Contact Pattern GM 10-Bolt leejoy Transmission - Rearend 52 12-15-2006 06:26 PM
Ring & Pinion Setup - GM 10-Bolt Help leejoy Transmission - Rearend 3 11-21-2006 07:02 PM
GM 8.5" 10-bolt Ring & Pinion Swap leejoy Transmission - Rearend 21 08-29-2006 10:11 AM
How hard is it to rebuild a gm 8.2 rearend? batman09 Transmission - Rearend 9 12-10-2005 12:54 AM
GM 8.2 differential bearing numbers? ken47 Transmission - Rearend 0 11-11-2003 01:29 PM
