Quincy Compressor Help
Brand new to the forum and need some good advice. I spotted a used Quincy Compressor i need some help with. I'd like to upgrade my Oilless craftsman for the home shop. Uses will be some sanding, grinding, cutting and impacts, etc. No plans for major blasting. So the unit is a 3 HP 17 gallon with a QTS-5, 4-cylinder pump.
Somewhat concerned with the tank size, but could probably get a secondary tank. Also - any ideas what this unit is worth? Have seen unit and it's in great shape. Thanks in advance. |
thanks for the thoughts oldred.... yep its a factory setup. i found some info :
Four-Cylinder, Electric Contractor Units cfm cfm cfm Tank Ship. hp rpm @ 40 @ 100 @ 125 Size Wt. LxWxH psig psig psig (gal) (lb) (in) 3 700 16.1 13.7 12.9 17 250 47x22x29 What's this unit worth? |
sorry - i see the last post got messy....
Factory Specs are: Four-Cylinder, Electric Contractor Unit 17 gal. Tank Size 3Hp 700 rpm 16.1 fm @ 40 psig 13.7 cfm @100 psig 12.9 cfm @125psig Wt. 250 lb |
Hard to say what it might be worth but it should be a good compressor if it's in good shape. Looks as if the CFM rating is higher than I thought and if you could find one it would work nicely on a 60 gallon tank.
| Recent Garage - Tools posts with photos |
| restoring a pre 1940's Quincy compressor | hera_n_clyde | Introduce Yourself | 3 | 11-22-2011 07:05 PM |
| Rebuilding Quincy 325 Compressor | Joelk | Garage - Tools | 17 | 10-17-2010 06:37 AM |
| quincy air compressor | gsmoljan | Garage - Tools | 2 | 07-28-2010 05:24 AM |
| quincy air compressor | gsmoljan | Garage - Tools | 1 | 07-28-2010 12:10 AM |
| Old Quincy air compressor | johnnyone | Garage - Tools | 5 | 11-04-2009 12:57 PM |
