Quqrter panel removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 07:08 PM
Can any one give me some pointers on removing a rear quarter panel on a 78 El Camino.
Old 03-19-2012, 07:45 AM
I have a video of replacing a bedside. This will be a little different and you will need to section the side panel to roof area. However, the locating and drilling spot weld parts will be similar. This may not directly answer your question, but hopefully it will help you some.
The Following User Says Thank You to Donnie Smith For This Useful Post:
redsag 78 (11-05-2012)
Old 03-24-2012, 12:46 AM
Thanks Donnie, is there a particular type of bit that is used.
Old 03-24-2012, 09:48 AM
you can use a normal drill bit but this make life difficult as you'll drill through both panels so it makes plug welds more difficult.
Preferably over that you can get a spot weld cutter bit, which is basically a little quarter inch hole saw. Maybe I don't have a good one, but I hate my spot weld cutter bit, it jumps and skips all over the place before it gets started and is still really easy to cut through both panels.
My preferred method, and I was taught this by more than one body guy, is to take a 3 inch cut off wheel and grind the spot weld away by holding the wheel perpendicular to the spot weld and just going back and forth across it, stopping when you can see you've ground away the top panel and can now see the bottom panel. This leaves the bottom panel completely intact. This is assuming you're tossing the panel you're removing because it grinds away a lot of metal at each spot weld location.
The Following User Says Thank You to Lizer For This Useful Post:
2000 olds Alero Door Panel Removal gfestep Interior 1 02-09-2010 01:51 PM
installing color panel in door panel studebaker2 Interior 1 12-30-2009 06:45 AM
1993 Chevy Silverado door panel removal lelshaddai Interior 2 01-19-2008 07:51 PM
63 Nova Door Panel Removal bowserhound Interior 3 07-08-2004 08:17 AM
cracking where fibreglass panel grafted to metal panel goldstarr Body - Exterior 2 11-22-2002 06:44 AM
