Qustion on Reverse Piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 11:14 AM
seven1nova's Avatar
Qustion on Reverse Piston TH350
on the reverse piston of a TH350, is a V6 bigger than a V8 and can I machine it down like the direct piston to add a fifth clutch or is four good enough for a V8.
Old 04-08-2008, 12:05 PM
Wiki Edits: 85
Originally Posted by seven1nova
on the reverse piston, is a V6 bigger than a V8 and can I machine it down like the direct piston to add a fifth clutch or is four good enough for a V8.
There is no way you can machine a reverse piston in a BMW to make room for more clutches.
Old 04-08-2008, 01:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Yes the piston can be machined down... you need a lathe and proper tooling to cut the aluminum piston down if needed.
Old 04-08-2008, 01:20 PM
seven1nova's Avatar
Crosley
Can you tell me Aprox. how much it needs to be cut down and if I should cut it down for a V8 App.
Old 04-08-2008, 05:24 PM
DeathRattle's Avatar
Some Punk Kid
Whats the thickness of the frictions you already have and plan on running?
Old 04-09-2008, 07:20 AM
question-350
Measure the thickness of one friction and one steel clutch, to give you your amount to machine off of the piston.
Or go to a trans shop that has been around for awhile and see if you can obtain a piston from them.
Old 04-09-2008, 11:28 AM
seven1nova's Avatar
Cool Thanks guys
Old 04-09-2008, 11:46 AM
31 five window
Last journal entry: grill and rear end
What does a BMW have to do with his question?
Old 04-09-2008, 11:49 AM
seven1nova's Avatar
Have No Ideal
Old 04-09-2008, 08:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Machine the piston down the thickness of an additional steel and friction... also , additional .010 for clearance.
just the way I do it.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 05:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
