r terminal on solenoid 67 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2004, 10:26 PM
hello i just put in a high torque starter im trying to wire the starter the right way i dont know if the car used a r - terminal wire or not do i need it? or just the s - terminal i have a mallory unilite with a resistor and voltmaster coil what is the proper wiring from ignition to starter to coil. it is confusing trying to figure this out thanks a lot for help.
Old 03-05-2004, 10:53 PM
BOBCRMAN@aol.com's Avatar
The extra terminal is for use with non electronic (points type) ign systems and bypasses the resistor temporarily to get a hotter spark for starting purposes. Not required with the Mallory unit.
