R134a Manifolg Gauge Set Readings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 12:33 AM
I've been using an R12 gauge set for years and am very acquainted with them. Yesterday, I purchased a US General set from Harbor Freight that are for R134a. The gauges are kind of confusing to me because the R134a scale starts at -5 and then goes up to positive numbers. In the center of the dial, you have a conventional number scale. When I read the R134a scale, the reading is +10 on the low side and +65 on the high. But according to the center numbers, its more like 45 and 250. I'm gonna take a picture later and post it. so which one is right? I'm thinking the center one of course - but what are all those positive and negative numbers on the R123a scale for? One other thing - the vacuum scale is located on the inner scale and goes down to 30 hg.
Old 07-11-2011, 01:19 AM
Here's a picture
Name:	r134a gauge.jpg
Old 07-12-2011, 07:34 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Looks to me like those would be head temps on the low and high sides. +10*C on the low side would equate to about 45-50*F, 65*C on the high side would work out to 150-165*F on the high side.
Vacuum gauge readings with performance cams eric32 Engine 9 11-21-2009 01:12 AM
vacuum gauge readings GMR Engine 11 08-25-2008 12:03 PM
Vac. gauge readings.... Slant3 Engine 3 06-24-2004 11:11 PM
Voltage Gauge Readings horvath Electrical 2 10-18-2003 10:04 PM
Voltage Readings on New Gauge - Overcharging? horvath Electrical 9 05-19-2003 03:49 PM
