R154 5 speed - Anyone using them? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2004, 06:42 AM
New Member
I know the Toyota R154 5-speed trans is stout and will hold a fair amount of HP (and relatively cheap). I'm thinking of putting one behind a mild 360 and stuff it in a 71 Dart. The extra gear would REALLY be nice for hiway driving. Are any of you guys using this trans?
Thanks,
49T&C
Old 11-19-2004, 12:01 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Certainly worth looking at
that is probably worth taking a look at (using the tranny) I think the main issue might be getting the proper bellhousing to bolt up to the 360..
just my thought..
OMT
Old 12-06-2004, 01:43 PM
It's not as tough a task as you think. I haven't done it but I know it's been done down in Australia. If you use a bellhousing from a 93-00 Dodge Dakota V6, it will bolt right up to the small block. You'll also need a special clutch disk from Advance Adapters and a pilot bushing from them as well. The R154 is plenty tough. I think the biggest issue you'll have is cutting the tranny crossmember under the floor and re-inforcing it for clearance.
http://www.jeeps-offroad.com/showthread.php?t=4740
Greg
Old 12-06-2004, 01:47 PM
So yes, they bolt together nicely...
R154 and $50 Dakota V6 bellhousing...
Greg
Old 12-06-2004, 02:46 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Good transmission.
My only complaint is that the shift forks are secured to the shift rods by way 10mm head bolts. I have broken one of those bolts before. Since this is not a drag car I guess that speed shifting will not be a big issue for you...just thought I'd add my 2 cents and experience.
