R154 to small block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2004, 04:13 AM
I just did a search on the forum, found a post that covered this but confused myself!!!????!!
I have a toyota r154 manual gearbox I want to mate to a small block chevy 350.
Can anyone tell me which bellhousing/adaptor plate to use and details of a clutch set-up would be helpful.
The engine will be rebuilt to around 350 hp and maybe later 100hp nitrous - will this transmission handle it? The car won`t be used for hard strip launches but will be used on the street with an occasional track day. The car weighs around 1100kg.
I have also heard of an upgrade involving a "thrust washer" in the gearbox - anyone have any info on that?
Thanks
Old 03-21-2004, 08:41 AM
Nobody know?
Old 03-21-2004, 09:59 AM
Jmark's Avatar
Hmm, tried to remember the web site for "advancedadaptors", but can't seem to find it. Oh well, sorry!
Old 03-21-2004, 12:38 PM
Jmark
Thanks for replying - thought everyone was ignoring me
I found the website....
http://www.advanceadapters.com
If I find the right info there I will post on this topic so it is available for others
Thanks
Old 03-22-2004, 02:46 PM
Doh
Having read the original post the information was already there...
http://hotrodders.com/showthread.php...highlight=r154
Now - got to find a clutch
Old 02-21-2011, 11:36 AM
Adapator plate for r154 - 350 chevy
Hi mate
Can you tell me if you did get the adaptor plate and clutch if so where ?
Snipes427
Old 02-21-2011, 02:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by snipes427
Hi mate
Snipes427
Snipes... Welcome to Hotrodders.com
You have posted to a near 7 yr old thread.
Old 02-21-2011, 05:33 PM
Hi mate
Snipes427
Hi
In the end I made up my own plate.
I milled a steel adapter plate to mate the tranny to a stock GM bellhousing. It took a while, but managed to keep it all within 0.02" and used 2 taper pins to lock the plate in position to the bellhousing.
It`s a while back now, but seem to remember having to machine a little off the length of the input shaft.
I turned a new brass spigot bush for the end of the crank.
I used a Zoom clutch (10.4" IIRC) and a stock Supra clutch disc. There was a difference in outside diameters of the disc and pressure plate, but it seems to work ok.
The stock clutch arm and release bearing worked fine.
Everything seems to work fine and the car has been on the road almost 2 years now and done around 6000 miles. Hard launches are fine with no clutch slip or judder.
The engine puts out around 380hp, similar torque although I never went for nitrous.
I`m quite surprised how the clutch handles the power considering they are mostly stock parts in there. I think it helps that the car is light - around 2300 pounds.
Time will only tell how long it will last.
Hope this helps.
Old 02-21-2011, 05:36 PM
Hi Crosley
I still lurk around here for time to time.
I am also still subscribed to this thread.
Old 02-21-2011, 06:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by dutch paul
Hi Crosley
yes, I know that.
Old 02-22-2011, 12:51 PM
r154 gearbox to mate 350 engine adaptor
Hi Mate
Thank you for the info it is very useful especially about the clutch. if you have any pictures I would appreciate (blade_3921@msn.com)
Many thanks
Old 02-23-2011, 04:40 PM
Hi Mate
Many thanks
I`m sorry - I never took any pics.
Old 03-13-2011, 08:59 AM
http://www.355nation.net/forum/engin...oming-out.html
Greg
Old 03-13-2011, 09:52 AM
Hi Mate
Many thanks
Adapter:
http://www.novak-adapt.com/catalog/kit_gmax15.htm
Bellhousing:
http://www.advanceadapters.com/produ...llhousing-kit/
You can get the clutch disk with Toyota splines from Advance Adapters as well as the pilot bushing.
Greg
