race fuel budget engine advice needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2013, 01:15 PM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
Basically ok looking into building a engine for my 89 Camaro. Looking to build something that's race fuel only. My local track ha 105 110 118 then methonal. I'm thinking either 383 or 396 Stroker sbc. I'm not looking for this to be to powerful but a good engine to build using junk yard parts. I'm going with a forged rotating assembly but not sure what else i need.
I'm looking for 600 horsepower roughly if possible. Any tips to point me in the right direction or good reads?
Old 02-17-2013, 02:42 PM
Banned
for 600hp you're not going to be able to use almost anything out of a junkyard, at least not if you want any sort of reliability.
Old 02-17-2013, 05:05 PM
cal1320's Avatar
"Budget" does not go with a 600hp race fuel engine. And it certainly wont come from a junkyard.
Old 02-17-2013, 08:38 PM
vinniekq2's Avatar
simple conversion
buy a 6 liter LS truck engine,buy 2 turbos off 6 liter ford diesels,make a simple platform on upsidedown cast exhaust manifolds, and run 15 pounds boost. injectors will need up grading
lol good luck
Old 02-18-2013, 07:02 AM
Banned
lol good luck
x2
if your are ucky you'll find a 6.2 ltr
Old 02-18-2013, 02:38 PM
Banned
lol good luck
or for a cheaper, and easier to find alternative- single turbo on a cammed 5.3L running E85. It'll still be a few grand before you're done but its about the cheapest way to hit 9's.
Old 02-19-2013, 05:08 PM
I was once in your position, the engine budget vs the fuel budget, although im a ford person the platform is basically the same, I used a 351w block with a stock crank and rods with kb forged 60 over pistons and molly rings, aluminum strike force heads and a competition products intake, I had it a 14/1 compression and running on turbo blue, but at $8.00 per gallon it was tough, so I sold the gas carb and bought a alky carb, changed over fuel system and run methanol. methanol here is $170.00 per 55 gal drum.
89 mustang with 351w on turbo blue at 1/8 mile ran 7's same car on methanol runs low 6's
Fuel line upgrade advice needed Chevymetal Engine 14 04-26-2011 07:41 AM
Blower Motor Fuel System advice needed DUKEOFBLUZ General Rodding Tech 1 08-05-2006 05:51 AM
General Engine Advice Needed kdj997 Engine 4 01-25-2006 02:07 PM
fuel line advice needed mike bryan Engine 4 12-04-2004 09:14 AM
new fuel delivery system advice needed dusterbd Engine 4 06-03-2003 06:13 PM
