race motor build up - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2002, 06:22 PM
Post race motor build up
I am in the process of building my first race motor and had a few questions about some of the parts.The block is a chevy350 .030over, i want to run at least 12to1 compression. I have accquired a set of vortech heads along with a matching proformer rpm intake. What would be the best cam to use? The engine will be strictly used for bracket raceing so good idle is not necessary.I will also be running a 750 holly. What headers would offer the best preformance,I do not plan on running mufflers? Any suggestions you have are more than welcome.
Old 09-25-2002, 06:33 PM
NAIRB's Avatar
Post
since this is a race engine, you should contact your favorite cam company on this one. You'll need to know your vehicle weight, your transmission type, and stall speed if automatic, your gear ratio, compression ratio, cylinder head work performed, desired rpm and expected performance. You can't just tell someone to use this or that cam in a "race" engine, you'll be disappointed if you do.
