racin - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2004, 12:38 AM
racin
wassup everyone i am new at this i have a question for the tech people......i have a 79 camaro i drag race and this past weekend after 3 passes down the track i had a lot of smoke coming out of the oil breathers on valve covers and i was just wonderin if ya might could help me
Old 06-10-2004, 02:11 PM
poncho62's Avatar
Wiki Edits: 5
Blowby..............piston rings.
Old 06-12-2004, 06:35 AM
Tazz
broke a ring
Do a compression test and see whats up then prepare to tear down the beast.
Tazz
Rat Rods Rule!
Old 06-12-2004, 08:27 AM
dmorris1200's Avatar
doesn't play well with others
Re: racin
If you are running breathers on both valve covers you probably don't have a functioning PCV system. That's cause for a problem right there coupled with worn rings and a lot of blow-by equals a mess.
BUILT FORD TOUGH
Old 06-14-2004, 10:22 PM
it could be head damage like valve guides
Old 06-28-2004, 06:02 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
if this is a new occurance you have problems. If it's always done this a bit, I doubt it's that serious.
My rambler's motor does the same thing-blows oil out of both breathers on the valve cover (six popper) because I eliminated the PCV system. You just need to install a PCV system on your engine. There are usually vacuum ports on aftermarket intakes just so you can plumb one just like a factory setup, or you can purchase kits with vacuum pumps to eliminate the pressurizing of the crankcase. You should make a few more ponies too after eliminating the pressure on the backside of the pistons.
