racing fuel system for 69 mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 10:54 PM
Guys,
I have a 69 mustang with a worked 302 that probably makes 350 horse and also has the 125 nitrous shot. I am planning on a motor upgrade at some point but my problem now is that my fuel pump seems to be dying. I have a gas tank sump and a holley blue pump. The last couple of weeks the pump quits when it gets hot. The gas tank is also leaking and the sending unit died a few years ago. I'm thinking about upgrading the fuel system and wanted to see if anyone has any suggestions. I know many of the new cars have fuel pumps that are actually in the tank. Is there a racing tank out their with a built in fuel pump that is a bolt in application for the 69 mustang? Another option I guess is I could gut the tank and install a fuel sump in its place. Has anyone here done that? Any advice would be appreciated.
Mike
Old 08-29-2010, 03:00 PM
Thanks for the advice. I already have 1/2" line and a fuel sump in the tank. The fuel sump line goes to a Russell race filter and then to the Holley blue pump, then 1/2" line up to the Moroso cool can and then splits after the can with a feed going to the nitrous solenoid and another to the regulator then carb. I need to replace the tank because it is leaking and now I also need to replace the pump. Since I have to work on the whole system, I was wondering if anybody has any info on fuel cells or replacement tanks with in tank pumps. I'm interested in cutting down on the pump noise if possible. I already have the new tank and a comp eng. fuel sump that I can weld onto it, but I wanted to know if anyone knew of a better option. I hear alot about these newer cars having in tank pumps and I"m wondering if they are a lot quiter. If anyone knows of a standard electric pump that could replace the Holley blue and run quiter that would be great. The current combo is not that demanding but I'm going to upgrade this motor one day and only want to do this fuel system once.
Thanks for any info.
Mike
Old 08-29-2010, 03:16 PM
ericnova72's Avatar
More for Less Racer
Mallory Comp pumps, and Holleys HP pumps are both gearotor design pumps instead of vane pumps like the Holley original design. Both are much quieter.
Old 08-29-2010, 04:41 PM
bigdog7373's Avatar
Of course it's fast
How bout a drop sump style fuel cell in the truck with an electric pump under the car.
Old 08-29-2010, 05:44 PM
techinspector1's Avatar
Wiki Edits: 326
This is the muffler hanging rubber I've always used to mount electric fuel pumps. Also, use a short piece of non-metallic hose coming into and out of the pump to further isolate vibes. She'll be quiet as a church mouse.
http://www.spintechmufflers.com/imag...THANGERKIT.jpg
I don't know if they still carry it, but I used to buy it in 6 inch lengths at Pep Boys.
Old 08-29-2010, 07:13 PM
I need a clarification. Do I use the muffler rubber to insulate the pump and bolt it in between the pump and frame, or do I actually hang the pump like a muffler and let it swing in the breeze? Also, do I actually use regular rubber gas line with nipple fittings going into and out of the pump to minimize the noise, or can I use steel braided line at this point?
Mike
Who hates NHRA's 12" rubber line rule? 454headache Hotrodders' Lounge 21 08-17-2010 08:48 AM
Fuel system plumbing Javelin69 Engine 3 05-14-2009 05:25 AM
street rod fuel system czmpjx General Rodding Tech 2 11-26-2007 01:58 PM
Octane Booster Info SLR_65 Engine 46 09-30-2007 10:01 AM
Blower Motor Fuel System advice needed DUKEOFBLUZ General Rodding Tech 1 08-05-2006 06:51 AM
