Racing Gear Oil Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2006, 10:19 AM
Sudden Psycho 31's Avatar
I have a question on what oil to use in the rear end of 9 inch floater. It is used in a short dirt track circle car with 6.2 gears. We have been using VERY high quality gear oil, which is super thick. I understand that it thins some when at operating race temperatures, but was wondering what others are using.
It seems that a little thinner oil would have less drag, and produce a little more power. You lighten every component you can... then drop in the gooey-est gear oil in the rear. Doesn't make a lot of sense.
Of course going remotely close to being to thin would make me nervous.
I guess I am just curious if anyone has experimented in this area. Every little edge helps.
thanks 31
Old 07-12-2006, 10:34 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Of course we know that chassis dynos record noticable improvements by using synthetics.
I am a big believer in synthetics. I would think that worn-in gears could use lighter weight synthetics without problems. Maybe with Lucas additive.
First I think that I would take some temp readings after each race using infra-red and see how hot it is running after say 6 hot laps, 10 lap race, and 20 lap features. That way you might know how much it is actually thinning.
I have heard that the cup-cars use very light weight lube for qualifying only.
8 years ago we just used 85W90 Mobil 1 and never thought about it... Your results could vary.... LOL
I have often wondered how much oil ends up in the axle tube with all that constant cornering. Usually cars never get truely straight.
www.readershotrods.com
Old 07-12-2006, 11:09 AM
302 Z28's Avatar
Run synthetic, you do not need the heavy viscosity. Royal Purple Max gear oil needs no other additives.
Vince
Old 07-13-2006, 09:28 AM
thanks for the info... i already run engine synthetics. i think i will try the royal purple and see what i get
i will try the temp readings, before and after, and let you know what i find
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
Gear Vendor racing juiced66malibu Transmission - Rearend 1 09-15-2005 07:53 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
distributor gear / oil pump rod issue?? bskaggs Engine 8 06-11-2004 08:02 PM
which gear oil to use? darom Transmission - Rearend 4 02-12-2004 12:45 AM
