Rack & Pinion ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2009, 05:07 PM
Rack & Pinion ?
Has anyone ever narrowed a manual MustangII/Pinto rack themselves and what's all involved in the process?
Old 10-21-2009, 09:00 AM
I narrowed my CTO (Center Take Off) which I think came out of a Celebrity or a Cavalier. I took an inch out of each side in order to clear my frame. I chop-sawed the rack on the left side and machined a new shorter cover out of...... yup, billet aliminum. On the power steering (right) side I shortened the piston rod and cover and welded in a new fitting and end cap. I then made new tie rods out of 4130 tubing with Heim ends after drilling and tapping the rack for SAE threads to eliminate the metric tapped holes.
I looked at several other rakes prior to picking the CTO and wish I had found a manual steering rack instead of power steering. The hoses and requirement to have a pump basically do little on a light car other then cost more and required more fabbing for brackets, etc.
On a more convententional style rack, it looks llike a matter of replacing the tie rods unless the rack itself needs to be narrower. When I looked at those style racks I thought the best approach would be to machine and heat treat new inner tie rod sockets in the rack and then fab new tubular tie rods either with Heim ends or tie rod ends.
My CTO rack may prove to be a poor choice on a car with a dropped tube axle due to the potential for bump steer. It would be a better choice on a car with independent front suspension....... time will tell as I'm a year or more away from the street with this thing.
It's cost to the tenth power and time to the twentieth power.
Old 10-22-2009, 04:43 PM
I was thinking it would be a challenge .I guess I'll find out .Thanks for the reply.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 10:24 AM
Looking for a 22 1/2 center to center power rack and pinion grobb284 Suspension - Brakes - Steering 5 09-28-2008 06:26 AM
Very Simple Power Rack and Pinion Steering Question djjc76 Suspension - Brakes - Steering 1 01-25-2008 12:43 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
