-   -   rack and pinion (http://www.hotrodders.com/forum/rack-pinion-168715.html)
noreastfish 11-19-2009 05:05 PM
rack and pinion
Has anybody cut the threaded ends on a rack and pinion? I am building a 51 chevy truck and installing a TCI front end. When I put the tie rods onto the end of the rack they are to long. I called TCI and they told me to cut the threaded ends. Has anybody cut the ends? When cutting the ends do you use a hack saw or does anybody have a better idea of how to cut them?
BOBCRMAN@aol.com 11-19-2009 05:53 PM
An air hand held abrasive cut off saw is much faster, with less sweat.
retrota79 11-23-2009 09:34 PM
make sure you put a tap on or nut before you cut it off so you can tap the threading right after
