rack and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2009, 05:05 PM
rack and pinion
Has anybody cut the threaded ends on a rack and pinion? I am building a 51 chevy truck and installing a TCI front end. When I put the tie rods onto the end of the rack they are to long. I called TCI and they told me to cut the threaded ends. Has anybody cut the ends? When cutting the ends do you use a hack saw or does anybody have a better idea of how to cut them?
Old 11-19-2009, 05:53 PM
BOBCRMAN@aol.com's Avatar
An air hand held abrasive cut off saw is much faster, with less sweat.
Old 11-23-2009, 09:34 PM
make sure you put a tap on or nut before you cut it off so you can tap the threading right after
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 10:24 AM
Looking for a 22 1/2 center to center power rack and pinion grobb284 Suspension - Brakes - Steering 5 09-28-2008 06:26 AM
Triumph tr-3 worm box swap with rack and pinion lugog Suspension - Brakes - Steering 1 06-29-2007 03:12 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
Mustnag II rack and pinion Echofive Suspension - Brakes - Steering 3 05-26-2004 06:26 PM
