rack@pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2011, 12:44 PM
chevynut1's Avatar
rack&pinion
It has been awhile since I have posted for several reasons, but things are looking up.
I have been told that a new rack and pinion could cost between $700-$1000 depending on the vehicle. How good are re-man units? Any one have experience with this?
Thanks.
Old 10-09-2011, 01:39 PM
The Maintenance Geek
For what?? Need more clues...
Old 10-13-2011, 10:16 PM
chevynut1's Avatar
rack&pinion
this is for a rack and pinion steering unit
Old 10-13-2011, 10:22 PM
evolvo's Avatar
No kidding
For a car or truck?
sorry, couldn't resist
Old 11-28-2011, 04:57 PM
chevynut1's Avatar
rack & pinion
guess I should explain better. I was working at a shop and when a car would come in and they would find a rack leaking, they would tell the customer a new one would be between $700 to a $1000. I was wondering if any one had ever used a reman. rack and how did it work out and the cost? Hope this clears things up a bit.
Old 11-28-2011, 05:27 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by evolvo
No kidding
For a car or truck?
Yep, I think that it was year, make and model that he was asking for.
Let's assume that we're talking about a PS rack for a '77 Mustang II.
NAPA Part # RAP-22200
Reman "long" rack ... includes the inner tie-rod ends.
Retails for around $250.00 CDN
Features & Benefits
Each Rack Is Surfaced To OE Specifications To Prevent Leaking Between Chambers & To Extend The Life Of The Unit; 100% New Premium Grade, High Temperature Lip Seals & O-Rings Are Used To Ensure No Leaking & Quality Performance; All New Spool Valve & Rack Donut Seals Are Installed To Restore Internal Sealing Of The Rack & Pinion; All Racks Are Tested 100% For Proper Flow, Pressure & Leakage To Ensure Performance; The Steering System Fluid Must Be Flushed & Replaced With The OE Recommended Fluid To Ensure Proper Performance Of The Steering System
Reman racks are actually BETTER than new, IMO, because they install a stainless steel bushing into the aluminum bore.
Old 11-28-2011, 07:23 PM
chevynut1's Avatar
rack&pinion
Thanks 66 GMC for your response. I thought that there should be a less expensive way to go.
Old 11-28-2011, 08:20 PM
Cape Cod Bob's Avatar
even less with the returned core.
Old 12-01-2011, 08:12 PM
New Member
Thanks
short wedding dress
simple wedding dress
rack & pinion tmcquaw Suspension - Brakes - Steering 0 04-07-2011 03:29 AM
S-10 with rack and pinion fierosum Suspension - Brakes - Steering 3 07-03-2008 07:32 AM
rack and pinion filbee Suspension - Brakes - Steering 6 06-26-2005 10:17 PM
rack&pinion bighotroddin Suspension - Brakes - Steering 1 09-05-2003 11:33 AM
Rack & Pinion Paul Pouse Suspension - Brakes - Steering 3 03-01-2002 05:42 AM
