Rack and Pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2003, 06:35 PM
bigvofnash's Avatar
New Member
Rack and Pinion
Hi. I have a 59 GMC pickup and want to put rack and pinion on it. Could anyone tell me from which vehicle I should get the rack from. The reason for rack is I want to keep the same suspension and install a conv kit for disc brakes, Thanks in advance
Old 08-06-2003, 06:48 PM
bowtieeater's Avatar
New Member
Location: I live in Rocklin, CA about 30 miles east of Sacramento.
I don't know what kind of suspension you have, but I would start by looking at rack and pinion in later model GM trucks. You probably won't find any units that will bolt on but I'm sure you could fabricate some brackets and figure out how to make it work. You will save a huge amout of money if you decide to fabricate something, rather than buying a bolt-on set-up
Old 08-07-2003, 05:30 AM
bigvofnash's Avatar
New Member
Rack and Pinion
Thanks for the info. I still have the orig front Axel, out side of brake conversion, engine, air cond and trans the rest will be orig
Old 08-11-2003, 12:13 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Let's see... 59 should have independent front suspension, right? The thing to look for is location of the rack next. Where is your drag link, in front of or behind the crossmember? Wherever it is, that's where you want your rack. Most front drive cars have racks behind the crossmember, rear drive in front. If in front I'd use a T-bird power rack (or Mustang, Aerostar -- all the same), if behind I'd go with a Ford Taurus rack or from some GM application. The Ford racks work great with a GM power steering pump.
The next problem will be turning radius. You'll lose a lot because of the length of the steering arms on the knuckles. Most R&P arms are only 5" center of ball joint to center of tie rod end. Stnadard steering box arms are usally longer -- mine are 7" from center of ball joint to center of tie rod end. Luckily my Rambler has separate steering arms so I can make new ones. GM arms are typically cast as part of the steering knuckle, so have to be bent or cut and welded.
The Ford inner tie rod end is also the rod itself. You can trim them if necessary to make shorter. Buy different tie rod ends to make longer. Mustang II and Escort (the boxy Ford made one) use a short tie rod end, Tempo and late Mustangs use one about an inch longer, and the T-bird uses one about an inch longer than the Tempo end. One should work for you.
