Rack and Pinion in a 57' ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2008, 07:39 PM
Seen a thread or two...but curious on if i should go power rack and pinion or power steering,it has none as of now :-P..Heard of cavalier conversions, how hard and expensive is this?
Old 05-02-2008, 01:02 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Could be quite inexpensive if you go the junk yard parts route or very expensive if you go the aftermarket parts route. Could be very simple if you have all the right tools and skills or virtually impossible if you are a novice car builder.
Old 05-02-2008, 01:16 PM
Irelands child's Avatar
Not sure why you would want to go all the work to install a rack and pinion setup. The '57 had a pretty good recirculating ball steering box and a fairly straight forward front suspension. I've had two '57's, a convertible and a tudor without power steering and the steering effort wasn't bad, especially with the big diameter steering wheel.
Dave W
Irelands child
Old 05-10-2008, 09:57 AM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
57 ford R/P vs stock
Have 57 RW...installed GEARHEADS p/s box-JUNK.Did WURTH-IT RACK drives great!Did you see my swaybar tread?
Old 05-10-2008, 12:09 PM
Is it comparable to any newer ride? So i could maybe go find that vehicle and test drive it to see if that's what i'm looking for?
I know some newer vehicles have that rack and pinion stuff...so..IDK???
Thanks BTW
Need power rack & pinion for '57 Belair Fiddy-7 Belair Suspension - Brakes - Steering 7 11-24-2007 02:29 PM
57 ford fairlane with power rack... h8louzn Suspension - Brakes - Steering 9 12-21-2006 08:09 PM
50 ford rack and pinion help jake100 Suspension - Brakes - Steering 2 03-05-2006 06:40 PM
Power rack and pinion 1954-55 Ford Hemi Boy Suspension - Brakes - Steering 0 02-12-2006 03:16 PM
92 Buick power rack pinion using 68 Ford pump? JAY221 Suspension - Brakes - Steering 2 09-14-2002 11:21 AM
