Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rack and Pinion in a 57' ford
Old 05-02-2008, 01:02 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Could be quite inexpensive if you go the junk yard parts route or very expensive if you go the aftermarket parts route. Could be very simple if you have all the right tools and skills or virtually impossible if you are a novice car builder.
