Hotrodders Bulletin Board
#1
Rack and pinion in 59 chevy?
Has any one tried to adapt a rack and pinion steering in a big old Chevy? My car is driven 20,000+ miles a year and I would like to improve the handling. It runs and stops well with a TPI 350 and disk brakes, but the steering is sloppy. The 59 Impala was converted to a GM 605 steering box which helped, but still doesn't compare to modern cars. At 3,800 lbs. I don't expect miracles, please give me some suggestions. If possible I would like to use common parts available through salvage. If need be, I can fabricate brackets, cut, weld ect. I would appreciate any help.
#2
No help from me ... but please read this other thread ... for applicable information.
http://www.hotrodders.com/forum/195...ring-91377.html Deuce ... Moderator ... |
#3
This is not a swap to take lightly. Simply "bolting" in a rack will more then likely hurt rather then improve steering performance. Read this article...
http://www.longacreracing.com/articles/art.asp?ARTID=13 There is a LOT of engineering involved here to make this swap work effectively AND safely. Mark |
#4
Great link ... thanks AstroRacer ...
Deuce ... Moderator |
#5
59 chevy rack and pinion
Thanks for the input, I believe I'll drop the idea of the rack and pinion for the time being. It seems there is a lot more complications than I had thought. I now have polyurethane bushings which has tightened up the front end. I guess I'll try big sway bars next.
Back to top |
Similar Threads for: "Rack and pinion in 59 chevy?"
| Rack & Pinion Steering on a Chevy C-20 Suspension? | Dusty82 | Suspension - Brakes - Steering | 3 | 03-01-2005 09:15 AM |
| rack and pinion 1955 chevy truck | chevy551958 | Suspension - Brakes - Steering | 1 | 09-20-2004 01:40 AM |
| 57 chevy rack and pinion | romine | Suspension - Brakes - Steering | 5 | 07-06-2004 07:43 PM |
| '59 Ford Rack and Pinion | kevkoracing | Suspension - Brakes - Steering | 7 | 08-22-2003 01:44 PM |
| What rack and pinion system works best on a 55 Chevy Belair | BigDaddyBugh | Suspension - Brakes - Steering | 4 | 07-02-2003 05:47 AM |
