rack and pinion conversion kit 48 Pontiac, Olds, Buick - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2014, 07:44 AM
Hi guys, I'm installing a Fatman rack & pinion in 1948 pontiac and have a 94 cavalier rack. using origanal suspension.
I'm having some problems locating exactly how to mount it. My instructions
say to hold the same height as the stock and center it of coarse which I'm having no problems. I have talked to fatman and am still not clear.
My problem is how far forward or back to locate it. I tried to line it up in the same location as the origanal location it is way off. It looks like it would have to move about 3" forward.
Has anybody installed one of these ? any advise, pictures of a similar install would really help me. Thanks Jeff
Old 08-02-2014, 08:31 AM
astroracer's Avatar
Hey Jeff,
I can't recommend any R&P installation on a box equipped car but you can do some reading to gain some knowledge with some of the problems you are facing.
Check out the articles here:
Technical Articles Steer#F
And also here:
http://www.woodwardsteering.com/imag...df%2064-79.pdf
The Woodward article gets into the fore/aft aspects of rack installation and they both cover the bump info very well.
Mark
Which rack and pinion kit for a 55-57 chevy powerrodsmike Suspension - Brakes - Steering 4 05-02-2007 07:21 AM
rack and pinion/conversion grandpaws 57 Suspension - Brakes - Steering 4 09-24-2006 11:52 PM
Rack and Pinion on a 58 Pontiac Ranchero_65 Suspension - Brakes - Steering 2 08-16-2004 10:00 AM
Rack and Pinion conversion? Crombie Suspension - Brakes - Steering 7 12-14-2003 04:04 PM
92 Buick power rack pinion using 68 Ford pump? JAY221 Suspension - Brakes - Steering 2 09-14-2002 11:21 AM
