Rack and pinion is locked up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2012, 02:23 AM
I am building a 50 F1 and have installed a mustang 2 front, I have it all together but the wheels won't turn. I know it's in the ball joints but why are they freezing up on me?
Old 05-17-2012, 10:04 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
How did you come to the conclusion it's the ball joints? Does it turn at all in any direction? Have you jacked the wheels off the ground and tried it?
Old 05-17-2012, 12:22 PM
Rack and Pinion locked up
Have jacked it up and still won't turn. I just assumed it was the ball joints. I'm going to take it all apart and see what's wrong
Old 05-17-2012, 12:42 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would think it is something in the geometry that is not right..try taking the rack off and moving it as it may need some spacers in the mount to get it to the right location..If the rack is not mounted correctly it can bind the steering.
Sam
Old 05-17-2012, 01:51 PM
Makes since, I'll check it out...Thanks
Old 05-20-2012, 10:51 AM
took it all apart and found that there was no grease in the ball joints, greased them up and worked them loose. added spacers and all turns freely now.....Thanks
Mustang II rack and pinion, pinion Jim H Suspension - Brakes - Steering 3 02-23-2012 11:58 AM
S-10 with rack and pinion fierosum Suspension - Brakes - Steering 3 07-03-2008 07:32 AM
rack and pinion filbee Suspension - Brakes - Steering 6 06-26-2005 10:17 PM
rack n pinion caper Suspension - Brakes - Steering 0 02-28-2003 02:42 AM
Rack and pinion CustomFord Suspension - Brakes - Steering 2 01-29-2003 05:30 PM
