Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rack and Pinion question
Old 02-17-2013, 07:45 PM
fasteddy_1947 fasteddy_1947 is offline
Last journal entry: Old guy's low cost Chev coup.
The caddy uses the center mount with the tie rods and ends. Reason I chose it was the tie rod ends are attached behind the steering pivot point (the kingpins) and I don't have to go over anything (exhaust manifolds, cylinder heads) or outside the frame to connect to steering wheel. I have a rack out of a camaro also, but it attaches in front of the kingpins and would steer backwards unless I turned the steering wheel upside-down or always remembered if I want to turn right, I have to turn left.
