Hotrodders Bulletin Board
#1
Rack & Pinion Steering
Fellow Rodders;
I have a 41 Willys coupe with a Mustang II Rack & Pinion. The car steers VERY well (no power steering) when I first drive it, BUT the steering gets VERY "stiff" the longer I drive (when everything warms up). After I let it sit for a while the steering is again fine. ANY IDEAS---Do I need a "NEW" rack and pinion?? Everything that I can lubricate I've done at least once!! Thanks Rick Dolinar |
#2
Sounds like something is getting hot and binding, not necessarily the gear itself. How tortuous is the linkage? Do you have more than one U-joint? Are there any severe angles in the U-joints? Did you design in a slip joint? This is a very important component to prevent expansion binding of the shafts. Would take a little work but can you drive it to stiff stage then put it on a hoist. Take each component lose and twist it by hand until you identify the bad boy.
#3
Rack & Pinion on 41 Willys
THANKS for your reply. I'll try your suggestion of getting it HOT, and checking everything on a lift. As you imply, it has to be something expanding when it gets hot.
THANKS AGAIN Rick Dolinar |
Back to top |
Similar Threads for: "Rack & Pinion Steering"
| Rack & Pinion vs. Power Steering?? HELP? | TheBreeze | Hotrodding Basics | 2 | 08-24-2005 07:06 PM |
| Rack & Pinion Steering on a Chevy C-20 Suspension? | Dusty82 | Suspension - Brakes - Steering | 3 | 03-01-2005 09:15 AM |
| Rack ANd Pinion steering | WilderRods | Engine | 2 | 01-23-2005 08:26 PM |
| rack & pinion steering | malibuman402 | Introduce Yourself | 0 | 08-11-2004 11:02 PM |
| power steering rack and pinion swap | Paco | Suspension - Brakes - Steering | 0 | 04-03-2002 06:56 PM |
