-   -   Rack & Pinion Steering (http://www.hotrodders.com/forum/rack-pinion-steering-12681.html)
litewaves 02-28-2003 02:30 PM
I have a 1949 ford coupe I installed disc brakes front and rear on original spindals and rear. I am looking for a R&P set up to use on the original front suspension also is their any kits out their for this ? or did anyone make up their onset up. If so what R&P did you/they use. I want to keep the front crossmember stock I am installing a modified flathead in it. Thank You litewaves
Mirror Image 03-06-2003 03:51 PM
I may want to check out thes guys http://speeddirect.com/Products/products.html they have canversions that may work on your car
