rack and pinion steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2010, 06:42 PM
Hello Fellow hotrodders: I have a 50 chevy tk short bed. with a 350 sb, auto. ps. pw. pb. @ air. ps. rack is out of 81' chevy citation. I had to do a lot of modifing, to make it work on my "strait" axel. ( welded brackets to mount it on axel) My problem now it leaks where the shaft goes into the top of the rack Would I be better off buying a reman or try to replace the seal? I kneed some input on what i'll run into trying to make these repairs Coments, sugestions as hotrodders BB is Jim Dandy
Old 02-26-2010, 08:22 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
It typically isn't hard to replace seals in rack and pinion steering units, but it can be challenging to get parts. I would look and see if the seal(s) you need are available, and then make your decision.
Andy
Old 02-26-2010, 10:02 PM
Andy
does the pump pressure have something also to do with this leaking ?
might he need a different relief spring in his pump ?
Old 02-26-2010, 10:20 PM
Have you driven the truck any distance ??
As a general rule ...
the set up you describe drives VERY BADLY ...
and the slip joint scares the H#^^ out of me.
Very Simple Power Rack and Pinion Steering Question djjc76 Suspension - Brakes - Steering 1 01-25-2008 12:43 PM
Rack & Pinion Steering Rick Dolinar Suspension - Brakes - Steering 2 07-02-2007 06:19 AM
Rack & Pinion vs. Power Steering?? HELP? TheBreeze Hotrodding Basics 2 08-24-2005 07:06 PM
Rack & Pinion Steering on a Chevy C-20 Suspension? Dusty82 Suspension - Brakes - Steering 3 03-01-2005 09:15 AM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 06:56 PM
