rack and pinion steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2012, 10:16 PM
I'M trying to find out what model power rack and pinion will fit in a 1957 Ford Custom with a 351 W engine. Granada spindles.
Old 05-14-2012, 08:14 AM
Wiki Edits: 27
Rear steer ?
If you have them mounted in the stock direction to have correct geometry you need to have a rear steer rack. There is a WIKI here on HR using a caviiar rack on older GM suspensions but I think it might not be strong enough for your weight of car.I have pieces of Jaguar f 40 front IFS to fab for my roadster and Caviliar racks.
The jags were bigger an bulkier. time to walk through the wrecking yard, a lot of things to consider. Pivot locations, overall width and interchange of tie rod ends, mounting etc. There are a couple of web forums on 5o's fords that might have more info , google , search, etc.
rack and pinion steering JAMES MEDLEY Suspension - Brakes - Steering 3 02-26-2010 11:20 PM
rack and pinion steering airofan Hotrodders' Lounge 1 09-20-2007 06:13 AM
Rack and pinion steering JesseD Suspension - Brakes - Steering 2 06-07-2006 01:12 PM
Rack ANd Pinion steering WilderRods Engine 2 01-23-2005 09:26 PM
rack and pinion steering LivinProof Suspension - Brakes - Steering 1 07-30-2002 08:44 PM
