Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rack and pinion steering
Old 07-30-2002, 07:44 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
You can do it. But it is easier to put the rack in front of the crossmember and notch the crossmember to clear the steering linkage. You can swap the spindles to make it front steer. If you leave it rear steer you will have to narrow the crossmember to make it work.
