Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rack on a tube axle
Old 09-12-2007, 06:09 PM
Youngster's Avatar
Youngster Youngster is offline
re: rack on a tube axle
Deuce is right ...unsprung weight is something that should be minimized as much as possible. It really has a negative effect on handling. Any handling issues get worse when you add more weight before the spring. Just curious, what was your reason for not mounting the rack on the frame? Are you going to run a panhard bar?
