Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rack on a tube axle
Old 09-13-2007, 08:31 PM
ajbcc2's Avatar
ajbcc2 ajbcc2 is offline
Last journal entry: frankenstude too
rack on a tube axle
yes..when i said fille the tube with grease..i was thinking that the shaft would displace it causing complete coverage.then with the withdrawal of it the 1/2 inch would allow air to be compressed as it worked in and out..this "air" secton would not allow the grease to transfer shock up the shaft..at least that was the theory.. all things considered it may be just the ticket to just coat the shaft then slide it into the tubing....less chance of the "grease shock transfer"..
