Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rad/Condensor/E Fan & Shroud Distance OK?
Old 05-08-2013, 07:36 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
The older Nissan Path Finder uses rubber flaps to seal the edges of the rad.These are very easy to install and fit easily.The idea is to make all the air go through the rads and not past them on the sides.The rad support had a big gap on the sides and when A/C was installed it needed sealing in the gap area. The last a/c I installed in path finders was back in the early 90s,not sure how much they changed.
