Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rad/Condensor/E Fan & Shroud Distance OK?
Old 05-08-2013, 10:39 AM
Roger Mabry's Avatar
Roger Mabry Roger Mabry is offline
Use hard AC foam from Lowes to fill holes
I used metal pieces screwed around the radiator sides to block the air from
bypassing the radiator.
Then used 2" foam from Lowe's to fill the gap at the top of the condenser
and around the sides not filled by the metal pieces.
Works great and car run cool in heavy So Cal stop and go traffic with the
AC on!
See the before and after pictures - lightish gray foam is installed in these pictures.
Name:	Side covers to redirect air.jpg
ID:	73854   Click image for larger version
Name:	Camara or Firebird radiator fit in Jaguar top right.jpg
