Rad/Condensor/E Fan & Shroud Distance OK? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2013, 10:09 PM
I am currently installing a Classic Auto Air a/c system and electric fans in my '65 El Camino with a 350 and TH350 combo. It has a brand new 3 core radiator repro to OEM specs.
The a/c condensor:
The condensor has a gap between it and the radiator of about 1/2". There is no way to get around this as the core support opening doesn't allow for the condensor to butt up against the radiator. Is this okay? The condensor covers about 90% of the radiator surface so I believe I have good coverage there. But I worry that the 1/2" gap may cause the air not to flow good thru it and then thru the radiator. Should I build some kind of flaps to run along the sides to cover this gap? Or is it okay and I shouldn't worry about it?
The electric fans:
I've purchased a Spal dual 11" electric fans that cover all but about 1/4" along the bottom of the radiator. I think this should be good enough, better than most fans I see installed. But in order to get it mounted to the stock radiator flange (the '65 rads have double flanges, one side to mount to the core support and the other side to mount the stock shourd) it leaves a 1/4" gap along the top and bottom between the fan shroud and the radiator core. Also when mounted, the fans blades are about 1" from the rad core.
First, is the 1" distance between the fans and the core fine? The fans are in a shroud (its the Spal 30102052 fans). Next, does the 1/4" gap along the top and bottom need to be covered up? I was hoping I wouldn't need to add too much fab work and not have a clean looking set-up. But, of course I want it to work the best cause of the hellish AZ heat and the a/c running almost all the time.
Any suggestions are welcome and thanks in advance for your help.
Jay
Old 05-08-2013, 06:36 AM
vinniekq2's Avatar
The older Nissan Path Finder uses rubber flaps to seal the edges of the rad.These are very easy to install and fit easily.The idea is to make all the air go through the rads and not past them on the sides.The rad support had a big gap on the sides and when A/C was installed it needed sealing in the gap area. The last a/c I installed in path finders was back in the early 90s,not sure how much they changed.
Old 05-08-2013, 10:39 AM
Roger Mabry's Avatar
Use hard AC foam from Lowes to fill holes
I used metal pieces screwed around the radiator sides to block the air from
bypassing the radiator.
Then used 2" foam from Lowe's to fill the gap at the top of the condenser
and around the sides not filled by the metal pieces.
Works great and car run cool in heavy So Cal stop and go traffic with the
AC on!
See the before and after pictures - lightish gray foam is installed in these pictures.
Name:	Side covers to redirect air.jpg
ID:	73854   Click image for larger version
Name:	Camara or Firebird radiator fit in Jaguar top right.jpg
Old 05-08-2013, 01:23 PM
sedanbob's Avatar
As others said, cover the gaps between fan/shroud and radiator so all air pulled by fan comes through the radiator, not around it. 1/2" gap between condenser and radiator should be fine.
fan shroud barry crisp Hotrodding Basics 5 04-30-2012 04:53 PM
Fan distance for proper cooling ashman Engine 5 05-05-2010 06:26 AM
fan shroud flex fan and water wetter for valiant elcaminodragster Engine 15 09-05-2009 09:52 PM
Electric Fan-Shroud or no Shroud? Cole Engine 12 02-05-2009 10:35 AM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 02:10 PM
