rad/trans cooler question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2005, 12:16 PM
Toyman's Avatar
I am considering getting a 2 row Griffin Aluminum radiator. (19 x 31, 1" tubes) I currently have a stock SBC 2 core radiator in my 70 Chevelle (355 sbc). It works OK, but if I'm working the engine on a long hill, the temp creeps up to about 210*. I am going to switch out my T-stat from a 160 to a 180 also. I am running a Flex-a-lite dual electric fan, and have an 11"x 12" tranny cooler in phase with the radiator tranny cooler. The Al radiator doesn't have a tranny cooler in it, so I am going to run it solely thru the seperate cooler. Tranny temps rarely creep over 180*. I put more miles on the street than at the track. I would like to make this change in the hopes that it will run cooler on the street, and track. I also have a virgin 400 sbc that I am going to build in the future, and hope that this setup will work well with it also. Opinions, similar experiences, and helpful comments welcome.
Old 06-07-2005, 02:10 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
if you have that big of a transmission cooler, I wouldn't run it through the radiator at all. I think you'll see that your overall operating temps for your motor will drop when you're not pushing that hot trans fluid through the radiator. Try just hooking the trans cooler up by itself for a bit, and see how that works-
K
Old 06-07-2005, 02:21 PM
Toyman's Avatar
That's a good point, but I just pulled the motor & tore it down on Saturday. Always getting the cart before the horse I'm putting a new cam in and considering milling the heads a bit for some additional compression. I figured that this would be the time to make the change since everything is out. Spoke with Summit Tech, & they said 30%+ better cooling going from stock to the Griffin Aluminum. Sound reasonable?
Old 06-07-2005, 02:48 PM
Wiki Edits: 3
sounds reasonable, but you might not need it. I run a ~425 horse 10.5:1 388 stroker in my 2nd Gen Fbody and I don't have problems with the stock rado. I use an external trans cooler and my operating temps are only about 170 degrees.
Try your radiator first. Heck, the 20 minutes it would take to remove it if its not all that you wanted after the trans cooler swap is worth the 300 bucks that you'd pay for the aluminum unit if you didn't need it. Furthermore, aluminum does not cool as well as copper (its a little more durable material and saves weight) so the aluminum radiators are sometimes a LOT bigger than the stock, copper unit, and they're sometimes a big PIA to get to fit right...
K
T400 cooler question Miket Transmission - Rearend 1 04-07-2005 01:49 PM
radiator/tranny cooler question 280zxWith305 Engine 4 03-07-2005 10:10 PM
tranny cooler question dawg Transmission - Rearend 6 01-16-2005 09:01 AM
Hotrodders Guidelines -- READ ME Jon Suspension - Brakes - Steering 0 06-14-2003 06:03 PM
Tranny cooler question heavychevy Transmission - Rearend 11 03-03-2003 11:23 PM
