Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiant floor question
  #19 (permalink)
Old 02-26-2011, 05:16 AM
Old Fool's Avatar
Old Fool Old Fool is offline
Originally Posted by latech
I have heard some horror stories from some of the HVAC guys here in Northeast Pa about the concrete not being so friendly to the pex tubing.
It doent like the expansion / contraction thing as well as the chemicals from the concrete while curing.If it springs a leak for whatever reason ,you cant fix it.
Honestly If it were me, I would put in radiant baseboard around the perimiter of the shop, use an outdoor boiler and an oil fired one for backup with a heat exchanger. There are outdoor woodstoves that can be multifueled, but I have checked into that for my remod, and they arent as efficient as putting in a dedicated unit.
With radiant it feels warm all the time and it is very even heat. Fanforced only feels warm when it is running, it stirs up a buttload of dust and its impossible to put the "unit" outdoors to contain the burner away from the air in the shop(VOC , solvents thinners etc. explosion...you get it)
I like the outdoor woodburner my neighbor has, itkeeps his house at 80 degrees inside all winter long.
I have an oil fired burner and my house is small and tight, I have used 275 gallons of oil so far this winter.
If oil keeps going up, I will be getting an outdoor stove and putting in a heat exchange for the hydronic (radiant baseboard) system in my house. If the fire goes down at night the oil fired boiler will pickup the slack.
Linn A
That is just plain bs , Expansion and contraction? how much do they think that concrete slab grows and shrinks? PEX tubing has a 100% minimum expansion rate. How do you think it survives having the end expanded to insert a fitting , such as the Wirsbo PEX system uses? PEX tubing is not affected by concrete, it is designed to be used in concrete. Your source must be referring to someone who used some other type of tubing. Can't fix a leak? Yes it is a bit difficult to fix the leak, you need to chip the concrete away from the tubing to put a repair coupling in it, but unless you drill a hole in it there won't be a leak. A continious loop of PEX poured into concrete is virtually impervious to damage
