Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiant floor question
  #27 (permalink)
Old 02-27-2011, 05:42 PM
35terraplane's Avatar
35terraplane 35terraplane is offline
radiant floor heat
Originally Posted by trees
Bob, I use the term "loop" because the line /water leaves the manifold and makes its way through the coils and back to the manifold. A "zone" one or more "loops" off a common manifold and controlled by a thermostat. In my shop, there are two zones: one has 4 loops and one has 3 loops. The 4 looper covers 1400 sq ft and the 3 looper covers 1000 sq ft.
Before signing the contract for the system, I spent several evenings on the net where there is a ton of info on various systems. One thing that was common was copper is definitely the best tube for circulating the water: flexible, sturdy, and the best heat transfer rating PEC is the 2nd choice and the only reason I used it was the terrible price of copper tubing. Using copper would have almost doubled the cost of the system.
The pressure testing of the loops was a local code item, but I would have insisted on it anyway because finding a leak would be a bear and then the repair is not something I would want to do or have done.
Trees
Trees I used loop because I didn't have a clue on what else you call it.
After writing my post, I called the guy that built my house and shop, I got to thinking about a pin hole or something. He told me they did a pressure test, I guess I was sleeping in that day.
Bob
She was only a whiskey maker,
But he loved her still.
