37, adding another on the opposite wall would make you doubly good.
Trees |
Pressurize the PEX while pouring, any leak will be evident and easy to find as it will bubble up through the wet concrete, giving a chance to repair before the concrete sets.
pex radiant.
All splices- joints must be out of the concrete. continuous run under the concrete. as far as expansion contraction, I have seen concrete roads buckle in the hot sun . That should not be a problem inside a building out of direct sun. if you build over expansive clay soils you can have floor cracking. In a lot of areas the local building department already has area soil maps. I hit clay down at 4 ft. My engineer spec'd 3 ft sq footings with 12 in sq posts with 6 pieces of 1/2 rebar uprights with 3/8 hula hoops 6 in apart for the steel column supports. There has been no movement in the 20 post locations. The footings must be deep enough for the soil type or a grade post-beam system. 18 inch holes about 6 ft deep with rebar L'ed into the floor, and foundation walls about a foot thick floor around the edges and use lots of rebar in the floor slab. Plenty of crushed rock then poly vapor barrier, sand and foam insulation. Grade the area around the building to keep rain and snow melt water away. In my main 12 X 12 doorway I also brought out 1/2 rebar 18 inches apart to tie into the driveway slab The backhoe weighs about 10 tons. . In 9 years there has been no movement or cracking in the main doorway. . In the back door the slab has lifted about 1/2 inch, I didn't put in the rebar ties out like the front and the ground base level is 18 inches higher, not as good of drainage. I had about 100 yards of base gravel hauled for under the floor, I should have raised it more, but didn't like having to do a 3 ft in 40 ft ramp in front.
A qualified in floor heat guy will pressurize the loops for about 48 hours before the pour and leave it on until ready to hook up the system to the manifolds. Having pictures of the loops before the pour helps to ease you mind when core drilling for anchor bolts later.
Trees |
radiant floor heat
My house is the same I have five zones and they are each one loop no splices or breaks in tube from start to finish, And they run pretty close, when I say loop I might be using the wrong term, as the tube went back and forth across the room or zone, not a big circle. It's just like wiring a car less breaks in a wire less trouble. So one end was hooked up to the out manifold, the other to the return, there were no breaks in between. Bob |
I was questioning the info I got .I personally dont like pex anyway, too newfangled. I do understand what you are saying about the expansion and contraction of the tubing and the concrete. Like I said , what I have heard were horror stories, as far as I am concerned the jury is still out. Call me stupid if you like, I just dont jump on every NEW thing as the BEST thing. I see alot of posts that guys put up saying it is the way to go,must be something I am missing. I am kinda hardheaded
When I built my garage, I was pretty hyped about in-floor heating.
Yes a warm floor would be a godsend if you spend a lot of time lying or kneeling on it. The downside is that recovery times from opening a door would be considerable, and might even require a forced-air unit to re-heat the air. After studying all of that, and weighing the costs and risks involved ... I was persuaded by a few friends to simply install a radiant-tube heater, along with a couple of industrial-type ceiling fans. The radiant heat warms ME more than the air, but it also warms things like windshields and car bodies ... which in turn help to warm the air. My garage is well-built with 6" walls, vapor barrier, and R20 insulation. The ceiling fans help to circulate the air under the vehicles and to warm the floor to a relitively comfortable temp. They also keep the windows clear. In summer, the air movement over the cool engineered concrete slab helps to keep the garage at a fairly consistent and comfortable 20°C (70°F) temperature even during the hottest of days we get here. It was relatively cheap to purchase and easy to install, and very economical to run as well. I heat my garage continuously as I have pets that live out there, but friends run theirs only when they plan to use their garage. It only takes about 1/2 hour before it gets comfortable enough to be out there. Last edited by 66GMC; 02-26-2011 at 02:55 PM. Reason: Picture of MY garage with radiant heater and ceiling fans. |
Bob, I use the term "loop" because the line /water leaves the manifold and makes its way through the coils and back to the manifold. A "zone" one or more "loops" off a common manifold and controlled by a thermostat. In my shop, there are two zones: one has 4 loops and one has 3 loops. The 4 looper covers 1400 sq ft and the 3 looper covers 1000 sq ft.
Before signing the contract for the system, I spent several evenings on the net where there is a ton of info on various systems. One thing that was common was copper is definitely the best tube for circulating the water: flexible, sturdy, and the best heat transfer rating PEC is the 2nd choice and the only reason I used it was the terrible price of copper tubing. Using copper would have almost doubled the cost of the system. The pressure testing of the loops was a local code item, but I would have insisted on it anyway because finding a leak would be a bear and then the repair is not something I would want to do or have done. Trees |
radiant floor heat
After writing my post, I called the guy that built my house and shop, I got to thinking about a pin hole or something. He told me they did a pressure test, I guess I was sleeping in that day. ![]() Bob She was only a whiskey maker, But he loved her still.
| Recent Garage - Tools posts with photos |
| radiant floor heat | price | Garage - Tools | 12 | 08-12-2010 05:39 AM |
| In floor radiant heating | billsnogo | Garage - Tools | 10 | 04-18-2010 07:47 AM |
| Floor pan question. | Hippie | Body - Exterior | 0 | 04-20-2007 07:40 AM |
| hydronic radiant heat- thats heated water folks. | kenseth17 | Garage - Tools | 1 | 12-28-2006 08:21 PM |
| Floor question | Rufus_2 | Interior | 1 | 12-28-2005 07:35 PM |
