Radiator Boilover - I'm stumped - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2004, 06:12 PM
Bill Ford's Avatar
Installed the Heat and A/C unit on a new chevy crate 350 that had been running with no overheating problems. All I did was remove the plugs from the manifold and water pump, replace them with heater hose barbs and hooked up the heater hoses. I also replaced the thermostat housing gasket which had been leaking a little.
I drained the water/antifreeze from the bottom of the radiator and replaced it after making all the connections. After cranking and running the engine for about five minutes to allow warm-up, I noticed coolant coming from the over-flow tube. Thinking this was just extra coolant being pushed out by expansion, I drove it about 1/4 mile or so and stopped to talk to a friend - it was still pushing coolant out at a rapid rate. I shut it off and let it cool a bit, we could hear boiling in the radiator. Drove it back home and let it cool again, removed the cap and added water to refill the radiator.
Cranked it up again, with the cap loose, and after about 3 or 4 minutes it began to gush out the radiator fill. I bet it pushed out a gallon in 30 seconds or so. Thinking I had an air bubble in the system, I let it set a few minutes and filled it up again. Left the cap off this time and cranked it up again - same thing, water gushing out the radiator.
Any ideas what's happening?
Old 03-03-2004, 06:51 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
It sounds like the radiator cap is bad. they go bad pretty often with me.
Old 03-03-2004, 07:05 PM
Pony's Avatar
Sounds like a thermostat problem. In upside down, left out or just plain bad. Top it of cold and start it cap off, after a minuate or two grasp the top hose firmly but don't colapse it, ( DO NOT get tagged by the fan doing this!) when the thermostat opens at it's opperating temprature you should feel water start to flow thru the hose and into the radiator (with the cap off you will see it to). When the thermostat opens the water level will drop also, as it does top it off. If this Does Not happen, you have a problem with the thermostat not allowing the water to circulate and cool as it should. No circulation = the water in the block boiling and reliving pressure back thru the lower hose an out the top of the radiator.
dmorris1200's Avatar
doesn't play well with others
Sounds like she might just be airbound. Did you follow procedure for burping her after refilling the system?
BUILT FORD TOUGH
Old 03-03-2004, 07:13 PM
302 Z28's Avatar
I think dmorris1200 has hit the nail on the head. That is my guess also.
Vince
Old 03-03-2004, 07:39 PM
BattlestarOne's Avatar
9 Second '63
Sometimes jacking up the front end of the car to get the radiator fill point as high as possible will help. The bubble will sometimes find it's way to the top if you give it some help.....let it idle while slowly filling the radiator.
Old 03-03-2004, 08:21 PM
4 Jaw Chuck's Avatar
Ditto.
— Han Solo
Old 03-03-2004, 09:55 PM
poncho62's Avatar
Wiki Edits: 5
Typical airlock..........
Drain some coolant out, start it up, bring up to temp and fill slowly with it running. That should cure it.
Old 03-04-2004, 06:09 PM
Bill Ford's Avatar
Thanks for all the advice, guys. Turned out to be a stuck thermostat - last thing I thought of on a new crate engine. I didn't know a stuck thermostat could cause a boil-over so quickly.
Old 03-04-2004, 06:53 PM
Well it certainly doesn't make sense that a thermostat would fail simply because you changed the housing gasket since you did say she ran fine before you worked on her. Guess you never know. Maybe it was damaged when you pulled it apart. At least it's ok now.
BUILT FORD TOUGH
