Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiator cooling fan??
Old 10-23-2002, 05:02 PM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
Post
Awsom: It has always wanted to overheat when not getting moving air flow. I am running a 160 degree thermostat with 40 BELOW cooling additive which seemed to help. I am not sure what CFM the electric add on is. It is mounted about two inches away from front of raditator because of mounting frame. Have you heard of any luck using the shiny shroud that JC Whintey sells. I am wondering the benefit of going all electric and eliminating the flex fan?? Any ideas?? DAVE E SHANK
