radiator core support bushing 65 el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2008, 03:16 PM
defilade's Avatar
2012
can some one talk me thru this I am swapping radiators and i dont understand
radiator core support bushings i am sure they are necessary maybe mine werent installed correctly so i want to do it right this time.
thanks,
wil
Old 12-23-2008, 12:41 AM
SSedan64's Avatar
Not exactly sure what you're asking? They go between the frame and the bottom of the Rad. core support.
Old 12-23-2008, 08:23 AM
CustomConspiracy's Avatar
Core support bushings
On my 65 C10 they are "U" shaped rubber pieces that provide protection between the rather soft brass/aluminum radiator core, and the hard steel frame of the truck.
If these two were mounted face to face the vibration would soon wear a hole in the radiator.
I googled " core support bushings" and got about a dozen hits...looks like you can replace them for about $20.00
If things are tough you could probably fab them out of some other rubber stuff but I would not run without them.
Old 12-23-2008, 02:10 PM
defilade's Avatar
2012
thats probably why im replacing my radiator now. they were on there when i pulled the old radiator out but they were badly worn, i was trying to figure out the correct configuration. so the radiator just rests on top of them and is not bolted to them right? ok thank you kindly
Old 12-23-2008, 06:04 PM
SSedan64's Avatar
You must have an aftermarket or a radiator from another car if this is for a 65 ElCamino. The stock type radiators bolt to the spacer & core support, metal to metal. Does yours have the metal frame on the sides with bolt holes?
Old 12-23-2008, 06:14 PM
Yes I would do a search if I were you. They showed several different types. It's hard to tell if mine is stock...several folks have owned this truck.
I saw ones that had round rubbers with bolts thru the center. Sounds like they would work just like he mentioned.
Old 12-23-2008, 07:39 PM
SSedan64's Avatar
Yeh, the 64-67 radiator bolted to the core or cross support. 68-72 had 4 rubber C-shaped pads, 2 on top & 2 on bottom then a metal cover on top that holds the radiator in place.
Old 12-24-2008, 10:12 PM
defilade's Avatar
2012
ya it bolts up on the sides 4 bolts two on each side after i took off the fan shroud and those bolts and the hoses it slid right out there are two what looks like large washers underneath with rubber bushings that hook up through the bumper one of them was chewed up pretty bad is that what i bolt the radiator to?
What vehicle to buy for swapping parts into el camino 1970Chevy General Rodding Tech 4 09-28-2007 08:31 AM
454 in 65 el camino Haulin Ace Suspension - Brakes - Steering 5 04-18-2007 06:45 PM
454 in a 65 el camino Haulin Ace Introduce Yourself 4 04-18-2007 08:39 AM
65 El Camino Oil Pan Removal JEC Introduce Yourself 2 10-14-2005 12:39 PM
factory harness for 65 el camino ekcaminoron Electrical 2 02-01-2003 05:06 PM
