radiator cost - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2012, 12:06 AM
radiator cost
Where can I get a radiator for my 48 ford truck with chevy engine that not going to cost alot. Thanks
Old 04-13-2012, 08:35 AM
delawarebill's Avatar
rad's
have u ck'd ebay ?????
Old 04-13-2012, 08:50 AM
malc's Avatar
Living At The Speed Of Life
Summit search..............ouch, īspensive.
Old 04-13-2012, 09:18 AM
Frisco's Avatar
Glad To Be Here
Many have used a mid '90's V-8 Mustang radiator with success using the small block Chevy engine. Cost new is around $100-150.
Old 04-13-2012, 01:05 PM
johnnyg's Avatar
hold my beer and watch this!
Go to the U pull it and find the best match, then make it fit.
Old 04-13-2012, 01:13 PM
Ive checked e bay, they 400 and up--Thanks
Old 04-13-2012, 01:18 PM
35terraplane's Avatar
Radiator cost
Frisco Had a good answer. Measure what will fit in your truck, then go down to the Radiator shop and look one up that's about the same size, hell they might be able to get one for your truck.
I have a Mustang in my 33, the photo on top, but I have a %.0 Ford, but it would keep a chevy cool.
Bob
Old 04-13-2012, 02:52 PM
poncho62's Avatar
Wiki Edits: 5
I used a 55-57 Chevy rad in my 51 F1 with Chevy engine....almost a direct bolt in, just make a couple of brackets
Old 04-13-2012, 03:28 PM
radiator
Thanks much I will check that out with the the radiator guy at pomona this sunday.
Old 04-13-2012, 05:29 PM
41 kustom's Avatar
Radiator
Check Speedway for a racing aluminum radiator. worked for me. I think Summit might have them now also.
Old 04-13-2012, 09:06 PM
1971BB427's Avatar
A radiator for a '65 or '66 Mustang is a very nice fit, and works well, as will a Tri 5 Chevy radiator, but the Mustangs are usually cheaper. Be sure to get one with two 1" rows if your engine is built a bit. A friend is using one and it cost him $159.
Old 04-13-2012, 09:21 PM
nine4gmc's Avatar
This^. measure what fits, see what side you need hoses to be on, then grab a bag of tools(don't forget the tape measure) and go to the pull a part. I have found really nice all metal radiators there for $35 with a swap out warranty.
Old 04-14-2012, 02:47 AM
JeffB's Avatar
Here is the Mustang unit http://www.ebay.com/itm/64-66-FORD-P...ht_2606wt_1181 these are also a bolt in 1949-56 Ford cars,the Mustang 6 cyl radiators have the lower outlet on the drivers side for 1970 and later Ford V8 swaps.The measurements are posted so you can compare.
radiator pressure to correct radiator cap lb pressure lildrip049 General Rodding Tech 6 10-17-2011 01:31 PM
Mod a radiator ? Cost JeepsAreBuilt General Rodding Tech 1 05-29-2010 08:34 PM
How much would it cost 70 Chevelle ss Transmission - Rearend 1 03-23-2007 03:54 PM
How much would this cost 72CutSupreme Body - Exterior 1 06-01-2005 11:30 PM
