Originally Posted by XNTRCI-T
Your vent tube is flush with the BOTTOM of the tank? If that is the case, you have a bad part. The vent tube should come almost to the top of the tank, like the overflow tube in a toilet tank.
On my tank, I just left the vent tube as is. If the tank overflows, the coolant will just dribble straight down to the ground.
Yes both tubes are flush.... I'm gonna run home during lunch and swap it out if that's the case. I knew it didn't look right !!
