Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiator fan clearance problems.
Old 04-29-2013, 08:53 PM
sedanbob's Avatar
sedanbob sedanbob is offline
I have a '33 sedan, 350 - same tight engine bay. I used an electric fan - diameter same as the radiator width. I had a shroud made to improve the efficiency of the fan - pulls through the entire radiator, not just in front of the fan. I located the fan as high on the radiator as I could. That helped give me a little more clearance in that it put the fan motor (thickest part of the fan) above the water pump pulley. They overlap a little. I am also using the short water pump - reverse flow in my case because of the serpentine belt setup I used.
ID:	73614   Click image for larger version
The Following User Says Thank You to sedanbob For This Useful Post:
Darryl Welsh (05-03-2013)
