Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiator fan clearance problems.
Old 05-01-2013, 01:48 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is online now
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by sedanbob View Post
17" is about as wide as he can go in his '34. I am guessing that the 22" is the height of the core, not the whole radiator - most are 17" x 27" for '33s and '34s. That's what I have in my '33. My electric fan is a little bigger - closer to 17". So far it cools it just fine - even with the a/c on.
A shroud should cure your problem ,I have a 17 in fan and a hand made shroud ,I made it to fit full core size for extra cooling note notch for radiator hose,,works fine now even at idle ,I also changed my fan temp switch to come on at 185 ,not at 210 like the original that came with the fan,i have a 4 flu aluminum radiator ,and a BBC,the black strip at top of shroud is not a gap it is a rubber door edge guard to keep the shroud from rubbing the radiator.
ID:	73663   Click image for larger version
