Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Radiator fan clearance problems.
Old 05-02-2013, 03:03 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is offline
Built Not Bought
Last journal entry: 53 ad3100
Originally Posted by 496CHEVY3100 View Post
A shroud should cure your problem ,I have a 17 in fan and a hand made shroud ,I made it to fit full core size for extra cooling note notch for radiator hose,,works fine now even at idle ,I also changed my fan temp switch to come on at 185 ,not at 210 like the original that came with the fan,i have a 4 flu aluminum radiator ,and a BBC,the black strip at top of shroud is not a gap it is a rubber door edge guard to keep the shroud from rubbing the radiator.
I should have noted my radiator core is 22 wide and 26 high the shroud brings the air thru a 17 in fan for mor velosith at low speeds does no affect cruising air flow
