-   -   Radiator fan clearance problems. (http://www.hotrodders.com/forum/radiator-fan-clearance-problems-232357.html)
Darryl Welsh 04-29-2013 08:41 PM
Need help. I have a 1934 ford fordor sedan with a 350 chevy engine. I only have 1 1/8 inches from the water pump pulley mount to the radiator. I installed a 15 inch flex fan. The engine slowly just keeps heating up to 230 plus degrees, so I have to shut it down. Is there a mechanical fan that will work or even an electric one. Total distance from the radiator to a fan belt is approx. 2 5/8 inches. The radiator is 17 in. x 22 in. The water pump centerline is approx. 8 1/2 inches from the bottom of the radiator. Any suggestions? Thanks.
sedanbob 04-29-2013 08:53 PM
2 Attachment(s)
I have a '33 sedan, 350 - same tight engine bay. I used an electric fan - diameter same as the radiator width. I had a shroud made to improve the efficiency of the fan - pulls through the entire radiator, not just in front of the fan. I located the fan as high on the radiator as I could. That helped give me a little more clearance in that it put the fan motor (thickest part of the fan) above the water pump pulley. They overlap a little. I am also using the short water pump - reverse flow in my case because of the serpentine belt setup I used.
68NovaSS 04-29-2013 08:54 PM
SPAL and some others make a slimline series, not sure what the dimensions are, and you need a shroud, which some fans come with.
oldbogie 04-30-2013 11:36 AM
Radiator is kind of small 17x22, how many rows of tubes? I run an aluminum, 2 row 19x32 in an S15 it just gets by at idle, but does fine everywhere else.
Your installation will probably require you change to the short pump and all the accessory brackets and pulleys that go with that change. Plus a shroud between the radiator perimiter and the fan, even if you use an electric.
Bogie
sedanbob 04-30-2013 03:32 PM
17" is about as wide as he can go in his '34. I am guessing that the 22" is the height of the core, not the whole radiator - most are 17" x 27" for '33s and '34s. That's what I have in my '33. My electric fan is a little bigger - closer to 17". So far it cools it just fine - even with the a/c on.
496CHEVY3100 05-01-2013 02:48 PM
2 Attachment(s)
A shroud should cure your problem ,I have a 17 in fan and a hand made shroud ,I made it to fit full core size for extra cooling note notch for radiator hose,,works fine now even at idle ,I also changed my fan temp switch to come on at 185 ,not at 210 like the original that came with the fan,i have a 4 flu aluminum radiator ,and a BBC,the black strip at top of shroud is not a gap it is a rubber door edge guard to keep the shroud from rubbing the radiator.
Too Many Projects 05-02-2013 11:39 AM
Cooling Components: Satisfaction Guaranteed
The CCI 1730 is configured for just this issue. I haven't received mine yet to show detail but call CCI and talk to thier tech line. I'm retaining the long pump system too.
sedanbob 05-02-2013 03:35 PM
What car are you putting this in?
Too Many Projects 05-02-2013 03:54 PM
'38 Chev. The fan is mounted up high and at a slight angle to allow more room at the pulley. I can't find my notes from the conversation but it is less than 2" thick right at the pulley.
Rather spendy compared to others but comes recommended from a street rod shop where I got the Vintage Air from. It's 2 speed too and when wired into the trinary switch, it runs on low with the compressor on and high when the temp switch triggers it.
496CHEVY3100 05-02-2013 04:03 PM
I should have noted my radiator core is 22 wide and 26 high the shroud brings the air thru a 17 in fan for mor velosith at low speeds does no affect cruising air flow
sedanbob 05-02-2013 04:52 PM
Cooling Components makes a nice unit. In the front of my '33 ford, I have the short water pump, and still have less than 2 5/8" between the radiator and the water pump pulley. I could have had more, if I didn't have the big HEI distributor, or if I notched the firewall to set it back a bit more. Locating the fan as high as possible on the radiator allows the fan motor and water pump pulley to extend past each other.
I won't be switching now, since mine fits and works fine, but wish the CC folks gave some more detailed information, like a set of drawing with measurements at critical points.
Too Many Projects 05-02-2013 05:35 PM
I ended up calling them since their pic only says it allows more clearance. I agree, they should have a side schematic with the dimensions as they told me on the phone...:rolleyes:
I found my note pad with the drawing I made at the time. At 6" down from top of shroud, it's 2 5/8 thick.....at 11 3/4" down it's 2 1/4. At 12" down it's 1 9/16 and at 16" it's 1 1/2. My fan pulley is right at the 11 3/4 -12" down and will have plenty of clearance.
I have a small body Pertronix distributor and the engine is tucked back close to the firewall. I didn't build the car but from what I've seen, the PO did a lot of good things that are nice to have.
