radiator for a flathead t-bucket - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2005, 05:22 PM
dorksrock's Avatar
that one hot rodding kid
im planning on putting a flathead into my t-bucket and am having a hard time finding a radiator. im open to the chopped '32 style grill too. what has everyone else used?
Thanx,
Jordan
Old 06-13-2005, 05:33 PM
WPG juggalo's Avatar
Rookie Builder....
Last journal entry: Getting Started...
The Rads from Dodge Slant Six pick-up trucks are pretty small, if you fabricate some custom mounts you might be able to make one of those fit...
Old 06-13-2005, 05:36 PM
dorksrock's Avatar
any perticular years i should look at for thoses?
Old 06-13-2005, 05:41 PM
Rookie Builder....
Late 70's Early 80's.....if you can get me the measurements of how much room you have i can tell you if it will fit or not
Old 06-13-2005, 05:46 PM
dorksrock's Avatar
ill see if i can get those! thanks a lot for the help!
Jordan
Old 06-13-2005, 05:48 PM
dorksrock's Avatar
ok, iv got 22.5 inches between the rails
Old 06-13-2005, 05:49 PM
dorksrock's Avatar
26.5 inches end to end of the rails
Old 06-13-2005, 06:01 PM
Rookie Builder....
You have lots of room then....the Slant Sixes rad is only 18.5 inches across and 21 inches tall with the rad cap.... you should be able to make that fit into just about anything you want to....
it came in dodge pick up and I think a couple of Darts had them to... Its a Fairly common thing to find at a slavage yard....
As for fans...i would suggest using an electric fan off an ford areostar or somthing like that....there small and they are twice as efficent as any mechanical fan..
Good luck i hope it works out for you...
Old 06-13-2005, 06:09 PM
poncho62's Avatar
Wiki Edits: 5
I would think that you will need as large a rad, maybe double or triple core. I understand the flatties were bad for overheating. You also have to deal with the double rad hoses, top and bottom......Looks like a custom job to me.
Old 06-13-2005, 06:20 PM
Rookie Builder....
With an electric fan keeping it cool should be no problem...keeps my truck cool and the weather sometime exceeds 35 degrees celcius here in winnipeg...thats pretty F'n hot....and i bang through rush hour traffic like that..
as for double hoses...i dont know......i've never personnaly dealt with an old flat head before...
Old 06-13-2005, 06:27 PM
dorksrock's Avatar
i wounder if i could plum in a t so both hoses go into the one inlet and do the same for the outlet
Old 06-13-2005, 06:29 PM
dorksrock's Avatar
get what i mean
Old 06-14-2005, 02:47 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Ok, last week you wanted the plans. Did you build the frame already? Do you have a body yet? Do you have the flathead yet? If you're building your own frame you can always modify your rails.
Mike
Old 06-14-2005, 10:25 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
check tractor radiators too, I think they're likely heavy-duty since those engines see a lot of time under quite a bit of load. For you I'd check ford 8n radiators.
Old 06-16-2005, 10:55 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
You can get a new Mustang radiator for about $120
I got a three row for an early Mustang from mustangsunlimited.com I'ts narrow enough to fit between your rails and it's not too tall. Thats what a lot of people use. If you're putting out a lot of horespower, you'll need a custom one anyway.
Ford Flathead Six Speed Equipment DJD Engine 3 12-14-2009 06:16 PM
Flathead V8 ?'s " for school project" 51FordDuff General Rodding Tech 4 06-12-2009 02:55 PM
T Bucket Steering and Radius rods plans ken47 Suspension - Brakes - Steering 11 02-01-2007 05:39 PM
Flathead 50's Style mercflathead Engine 13 03-12-2005 10:00 PM
a crack in my flathead woodenshoedrags Engine 3 07-14-2004 07:30 PM
