Radiator Flush - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2011, 02:47 AM
KMyA
Radiator Flush
Not sure if this is the right place to post this. I want to flush my 4 row radiator and 400 engine both are in the car. I am looking for ideas on what solution to flush with. What do you guys use? How about a 1) dilute solution of CLR (calcium, lime, rust remover) or 2) baking soda and water? Would either of these take out the water pump seal? Not sure what concentration to use? Any one know the radiator & engine capacity for a Pontiac 400?
BT
Old 09-03-2011, 09:42 PM
327NUT's Avatar
Since the rad. is very easy to remove I would take it to a rad. shop and have them rod & core it or use whatever flush system is needed. I wouldn't flush all the scale and rust that's in the block into the rad., would cause more problems that it would solve. If you google "flush engine block" there's all kinds of info.
Old 09-04-2011, 09:58 AM
S10xGN's Avatar
Gotta love a turbo!
The heater core in my Dakota plugged up, I used a Prestone flush kit and followed the directions. Worked great!
Russ
Old 09-04-2011, 10:09 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I agree...
Old 09-04-2011, 10:17 AM
Rod and flush?
Don't take the radiator off and let a radiator shop get near it. When they remove the tanks and rod the tubes, the tubes are damaged beyond repair and the solder will not hold after they replace the tanks. Basically, a radiator shop can ruin a radiator. You may not be able to find a radiator shop because the EPA has just about put those guys out of business.
Get a new radiator such as Modine, for example, and you will not be taking it back off again in six months. Prestone has a flushing solution that works pretty good because the chemists at Prestone knows more about radiators than we do.
Always use Prestone 50/50 antifreeze coolant . It is 50% antifreeze mixed with 50% distilled water. Continued use of tap water will fill the smaller coolant passages with calcium deposits, or worse, if it is 'gyp" water. I used distilled water in my windshield washer tank and radiator. When Prestone came out with their 50/50 mix, I only use distilled water in my windshield washer tank with a pint of windshield washer antifreeze. Don't use more than a pint because it is alcohol and will damage the plastic washer components.
Old 09-05-2011, 06:14 PM
327NUT's Avatar
You must have some great rad. shops near you. I've had several done the way I explaned ....at quality professional shops and never had a problem. Of course buying a new unit is the way to go but sometimes the money just isn't there.
Old 09-05-2011, 06:47 PM
willowbilly3's Avatar
Last journal entry: Body mods
I used to have a flush tool I built, patterned it after a really old one I saw once. You would remove the T-stat and hook it to the t-stat housing which is bolted back to the engine. It had a garden hose and an air hose. Let the system fill with water and hit the air hose breifly. It usually took several cycles to bring all the scale out of the block. On a GM I always pinched off the heater hoses because I did blow a heater core once, never did on any other make though. I always did it back through the radiator and all the crap will come through, out through the top hose. If you do build one, put a check valve in the water side, you don't want shop air pressure into your water system.
Old 09-06-2011, 02:07 PM
el pollo's Avatar
It's shady under this tree...
I just pull the t stat out, bolt the housing back on, shove a garden hose into the housing and let the water flow pull everything out.
Old 09-06-2011, 04:19 PM
T-bucket23's Avatar
Wiki Edits: 26
The flush solutions work ok in the radiators. You will never get all the crap out of the block unless you knock out a freeze plug. I learned this long ago. We had flushed for a long time both ways through the block. We then knoced out a plug on both sides and the lower part of the water jackets were still full of rust and scale. Unfortunately this is not practical in all vehicles but if you have clearance it is your best bet.
Chet
flush radiator yes or no GMR Hotrodding Basics 5 03-11-2011 04:56 PM
CLR for radiator flush yes or no?? Rob Keller Engine 3 09-24-2005 03:54 AM
flush keith denson Introduce Yourself 1 07-11-2005 04:35 PM
how much for t-tec flush?.... sc2dave Transmission - Rearend 2 04-30-2005 09:21 PM
Radiator flush - KOOL CLEAN, CLR , etc which best to use? dbuff Engine 2 07-13-2004 10:37 PM
