radiator holdown bracket - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2010, 05:10 AM
topwrench's Avatar
Last journal entry: fish carb
I am in the process of installing a s.b. in a 1990 c1500. original eng was 4.3 , engine and trans are already in, my problem is how to hold down the rad. i am installing electric cooling fans and the radiator was originally held down by the plastic shroud for the v6 Ive installed correct radiator for for original v8 exept its 3 flue should be good for bout 400 h.p. Otjer than fabricating a metal top holddown so i can use the orinal to rubber saddles does anyone know who manufactures this part.
Old 07-20-2010, 09:32 AM
by 3 flue I assume you mean 3-core, meaning it didn't come on any trucks of the same year/model? (I'm more a ford guy)
If so, there likely isn't any option other than custom fabrication. There may be a way of making new mounting holes for your old hold down brackets depending on the setup, but it sounds like you're in for some cutting, drilling, bending, or welding.
Old 07-20-2010, 03:00 PM
topwrench's Avatar
Thanks I solved the problem by fabricating an aluminum bracket and using new rubber inserts for a b.b. rad from a suburban, yes i meant 3 core,sorry it was early in the morning.And thanks again for yuor help!!!!!!!!!
SBC Alternator Bracket Camaro2 Engine 2 10-04-2009 01:38 PM
TV kickdown cable bracket lwin517 Transmission - Rearend 1 03-24-2009 12:26 PM
Accessory bracket trouble...need help asap Titanium Hotrodding Basics 1 10-09-2008 08:39 AM
Moroso Throttle cable Bracket skeeveman Engine 2 02-14-2005 07:27 AM
q jets for B/O/P and caddy throttle bracket COCHEV Engine 2 07-15-2003 07:36 PM
